Calliper Refirb
RayM
 Cheltenham
Morning all
When I undertake my servicing work shortly and have the wheels off to do the pads and brake fluid I want to do something with the callipers that look a bit tired !!
Anyone have any refurbishment tips or experience, paint or coating that can be used etc ? I don't want to fit those tacky stick on covers :(
Regards.
If you are capable then remove them completely and have them blasted and powder coated with all new pistons and seals. Otherwise get a drill with wire brush attachment to clean them up, then get some high temp caliper spray from halfords or similar and give them a few coats of your favorite colour.
I believe eurocarparts sell a kit for this job
http://www.eurocarparts.com/ecp/p/car-accessories/car-maintenance-accessories/paints-and-primers/caliper-paint/?993771921&0&cc5_809
There you go :thumbsup:
<a class="vglnk" href="http://www.eurocarparts.com/ecp/p/car-accessories/car-maintenance-accessories/paints-and-primers/caliper-paint/?993771921&0&cc5_809" rel="nofollow"><span>http</span><span>://</span><span>www</span><span>.</span><span>eurocarparts</span><span>.</span><span>com</span><span>/</span><span>ecp</span><span>/</span><span>p</span><span>/</span><span>car</span><span>-</span><span>accessories</span><span>/</span><span>car</span><span>-</span><span>maintenance</span><span>-</span><span>accessories</span><span>/</span><span>paints</span><span>-</span><span>and</span><span>-</span><span>primers</span><span>/</span><span>caliper</span><span>-</span><span>paint</span><span>/?</span><span>993771921</span><span>&</span><span>0</span><span>&</span><span>cc5</span><span>_</span><span>809</span></a>
Cheers fellas :)
Another option is biggred. Remove them and send them in for the work. In fact i think they may even offer a drive in service if you are local...
http://www.biggred.co.uk/
+1 for Bigg red :thumbsup:
Hi Ray.
This kit is less than £10 in red, blue or yellow and should do the job for you.
http://www.ebay.co.uk/itm/221919406875?_trksid=p2055119.m1438.l2649&var=520811409387&ssPageName=STRK%3AMEBIDX%3AIT
nb67 said:
Hi Ray.
Cheers Buddy... that looks good value.
