After my CD changer became a little temperamental I had it removed (by the chaps at Didcot Auto Centre – always excellent!
) to fit an iPod adapter.
DICE Silverline
Ordered online and received in short order. Connected to the CD changer harness in changer slot. After hours of disconnecting the battery to reset the system and trying different dip settings it worked for a little while. It stopped working. Support was poor (dealer) but they did swap out. Second unit failed. Support was appalling! Gave up – dealer support aside as far as I could tell, when it did work, it was slow and very fussy about the iPod setup. :thumbsdown:
Dension GW300
Fed up with just 1 CD I thought I’d try again. Ordered online and delivered in a couple days. Install meant removing the air vents above the stereo – a real faff! Disconnected the battery. Disconnected the stereo. Dension cable connected and fed into the glove box. Reconnected the stereo then battery. All back in place. Works brilliantly. A bit of trial and error getting the text working but now very happy.
The Dension unit is Velcro’d to the top of the glove box, very neat. All that is needed now is to secure the iPod bracket to the back of the glove box. Only downside was having to buy the connection cable separately.
Not sure if I was unlucky with the DICE but the dealer service really was terrible. I was put off the Dension initially by the need to remove the stereo, but it really is an excellent unit. They actually function in a similar way – select different CDs for playlists, albums, artists, etc. Dension is definitely a lot less fussy. Using an old iPod which I just leave connected.
DICE Silverline
Dension GW300
