bulb fault warrning lamp goes on and on
pauld2012
Ive got a bulb warring lamp coming on then going off even when it in the daylight when im not using the lights , ive looked around the car with a neighbour help and i carnet see any bulbs out what should i do next ? is there a fuse i can take out to stop the warring lamp coming on ?
Check your brake and indicator bulbs, the filament cam be broken at one end and make and break contact due to vibrations causing the warning lamp to come on :)
I had a similar problem.
I discovered it was the headlight HID Bulb.
When it started to go it would intermittently "ignite".
Check the colour of the light.
"Pinkish" indicates it's on its way out.
Cheers and Good Luck with that.
Bumpy
ps When I first got my BMW, a friend who has a lot of experience with this marque told me to ignore idiot lights (at first) cause they often correct themselves. :driving:
