I have been working on another mod: building an air scoop from teh OEM air scoop (if you can even call it like that). Here's a short write-up of what I did
So for those who didn't know, this is what the OEM scoop looks like. You can find it behind the right kidney grill. You have to pull out 1 plug on the bottom right and then give the whole thing a good pull
I wanted to use the OEM part to keep it simple and to keep the original mount points. So I cut a round hole in the OEM scoop:
I cut a hole because I wanted to mount a simple plastic drain tube (left-over I had laying around) on the OEM part:
Putting it back in the right place, gave me a rough idea where to cut the pipe:
After cutting and sanding the edges, this is what it looks like:
I put a LOT of glue on the inside as well as a piece of plastic cut from a lid of an olf plastic box I wanted to throw away. I have chosen for a purple part, but any color will do
And this is what the final result looks like (before painting) behind the right kidney:
In the meantime I have spraypainted the whole thing red, as I wanted it to be visible. Of course you can spraypaint it matte black to make it look more OEM
As the paint takes AGES to dry, pics of the mounted scoop will follow later
That's why it got a coat of paint
