Rear springs are both gone I think, makes the rattling spanners noise I've read about on here. On the plus side however I changed my Transmission fluid for Royal Purple MTF and MASSIVE difference to gear changes. It's just got better and better each day as it's worked its way around. I Think I'll do another change in about 6 months to get the last lot of grit from in there. If you haven't done this and find your gears a bit notchy then it's well worth doing and takes 30-60 mins (I recommend a good hand pump (£10 from eBay) to get the new fluid in).
What's the deal with the springs? Is there a good how to guide and what's the best place to pick up some new springs?
