Deepseaskateboard
I have had a delightful issue occur.
The car in question is a Z4 20i with the N20.
The turbo air inlet pipe has broken.
Apparently it’s a common issue on N20s with the plastic part subjected to multiple heat cycles.
Part number
13717605638
So, my questions are as follows:
Has this happened to anyone on here?
If so, what was the repair cost?
It doesn't look too difficult to replace, apart from the bolt holding the pipe to the turbo.
Bearing in mind I am a mechanical novice.
There are many different supplier for part number:
13717605638
What is a good one? Is the OEM that good if they break? Is there a better solution anyone can recommend?
Looking for your collective wisdom.
Part number
13717605638
13717605638
