Brembo Brake upgrade *Update
D.Bryce
Front brake dust seals had burst so was time for an upgraded.
Bought the Freaky Parts kit for e46m3 which includes:
Brand new brembo brake calipers
Hel performance braided lines
Custom made billet mounts
Pads of your choice, I went for pbs pro track.
All mounting hardware
New pins and spring clips.
Hopefully get them fitted next week but for £800 I’m looking forward to seeing how they perform.
Just need to source a brake cooling kit now
Very nice, full kit! Are you doing like me, only changing fronts?
PocketGT: They’re Renault Megane RS.
I’m putting mine on now, had to scrape some material off to fit the CSL-wheels, will post pics later.
PocketGt: as mentioned above these are from the mk3 rs Megane. I believe there is also brackets available for the 966 calipers.
Argenta, can you explain a bit more about removing material ? I have genuine csl wheels but running a spacer. Assuming your issue was clearance to the inside of the wheel ?
Also only doing the fronts but rebuilding the rear calipers with new seals and pistons, braided lines and fluid.
Yeah I checked the depth of the cylinders and there was a lot of aluminium left to grind off, but I'll do some testing before I post results.
Obviously I'll have to bed in my new pads aswell (incl. heat cycles) so that will be the ultimate test. :)
CSL's fit without spacers, std 18" will prob need 3mm spacers.
How did you get on fitting these ? How’s the stopping power ?
Hi, havent even seen the car for over a week, no idea yet. (But I'd be VERY surprised if the stopping power is any different from OEM calipers)
Finally got the kit fitted but due to the calipers being slightly wider you will need a minimum 10mm spacer for clearance. Other than that it’s a straight fit and a great upgrade 👌🏼C4D75C21-92E1-4AC7-A6A8-62E6B6DD4DD1.jpeg
Got mine to fit the CSL's without spacers, the OEM 18" still need 5mm spacers. Very happy!
And they look so much better than the std calipers. Used the same 650deg silver paint.
Anyone else having issues with the HEL brakelines provided by FreakyParts? They're too short to be fitted in the corresponding caliper slot, but at an angle. Doesn't seem great & my left one actually came loose once (low speed luckily). Will see if they can provide 600mm ones instead of these 500mm.
Only minor gripe is some noise when hot, dunno if its the discs or the the caliper getting into some sort of self-frequency... Anyone else noticed this?
Actually bought the cooling kit from Westersund but decided to go for a more factory approach, in making the OEM cooling more efficient.
Then I used that same silver paint on the std rear calipers for matching! :)
It looks like one of the pistons on that caliper has broken off. If that's the case id be changing that piston. Something doesn't look right.
Hmm dont know how you mean? You mean the piston I temporarly took out?
In that case it was for measurment material thickness, before sanding the outside.
I ordered custom 8mm spacers to clear the OEM wheels (which I use with track AR-1 tires)
I see that's good, I thought it was a missing / snapped piston and that's how you were running them. My apologises
Anyone else running these Brembo (Trophy R) calipers?
I don't know if I'm imagining things but they seem to run hotter than std on trackdays etc, leading me to think the front bias is too much..?
I do have semislicks (Nankang AR-1) now which with extra grip may induce more heat aswell?
New carbotech pads this spring are now only 5-6mm, after a few evenings on Nurburgring and one swedish trackday. In total 7200km in use.
I have my std rears.
Then again, the bias is more rearwards than on a E46 M3 - but more forwards than the CSL (and the Z4M I presume)...?
