Brembo brake discs question
Dav the wheel nut
Veteran
 Somerset
Been looking to replace discs and noticed that some Brembo front discs are 300mm diameter and others 325mm diameter.
Can anyone say which is right or why there is a difference. I have a 3.0 e85
Thank you
Unless I am mistaken here, the 3.0 should have 300mm disks on the front, when the 3.0si has 325mm (this I am sure).
Which Brembo discs would you consider?
Thanks for that. I thought that was the case but needed confirmation.
Just bought drilled and grooved set on ebay discs and pads and got £50 off using promo code given in another post :thumbsup:
What size are they on the 2.5 E85 2004 model? It's just that I'm looking at a Brembo disc/pad all round replacement soon too.
Cool, thats a nice deal :)
Would you mind posting pictures of them once received? I am also on a pre-purchase investigation here, and still undecided if I go OEM like or if I choose to change for a bit and get drilled/grooved disks.
Also some have mentionned that only the front Brembo disks are coated, not the rears.
Something you may want to check as well.
That was me. They don't do a coated 294mm rear disc for the 3.0i/3.0si/2.5si.
The 2.5i needs a 280mm rear disc, which is part number 08.9859.81 for the coated version. They are really good quality - best resistance to rust I have ever seen.
[EDIT] Fronts are 286mm vented. Try 09.5390.31.
