Ali0191 said:Ah it’s the sport button!
Any chance the cabling is fitted for retrofitting?
I believe so- I can look and cut the cabling for you?
bigwinn said:Ali0191 said:Ah it’s the sport button!
Ali0191 said:also assume they are same for e86 and fairly simple to replace?
Ali0191 said:bigwinn said:Ali0191 said:Ah it’s the sport button!
That would be amazing, would you be able to take quick snaps of where it is connected to help me for when I fit it to mine?
what he said!Phippy said:Haha thought it might be a stupid question*, basically is it same regardless of facelift. Are does that mean they a real pain to take off/put on? :|
*had a look at some removal threads and have seen a couple of comments they are slightly different so this might not be quite such a silly question after all :/
Correction. realoem has a different part number for e85 and e86 panels, although all e85 panels are the same including pre/post-facelift and Ms.Zedebee said:Ali0191 said:also assume they are same for e86 and fairly simple to replace?
yes . . . and no!
don't get me started- easiest to do with the roof off!Zedebee said:Correction. realoem has a different part number for e85 and e86 panels, although all e85 panels are the same including pre/post-facelift and Ms.Zedebee said:Ali0191 said:also assume they are same for e86 and fairly simple to replace?
yes . . . and no!
There is one screw which is a real PITA to access. I’ve not done this, but I am sure [ref]bigwinn[/ref] and others will be able to enlighten you.
MKZ4000 said:Did you sell the bootlid as I was after the spoiler ?
bigwinn said:MKZ4000 said:Did you sell the bootlid as I was after the spoiler ?
Still for sale bud
no worries matey!Phippy said:Thanks Stuart.... luckily i won't have to mess about with the roof or the boot lid, but following some more research and a call to BMW unfortunately they are slightly different panels between coupe and roadster, hence different part numbers. Thanks anyway.
MKZ4000 said:bigwinn said:MKZ4000 said:Did you sell the bootlid as I was after the spoiler ?
Still for sale bud
If you remember I was after just the spoiler . Could you do for £120 posted ?
Bombardino said:Have you got a N/S door grab handle cover?
