Ducklakeview said:Any more thoughts peeps?
Mike
New pads can be a bit spongy where it looks like you have to press deeper. With the first presses when you load up the pistons and put pressure on the pads it looks like it then is very hard, but when braking again, in the meantime the pressure was off the pistons and pads, so you get that spongy feeling again.
Brake pads are porous and in time that will be filled with brakedust and it will glaze up and get hard.
At least that's what I experienced with my bbk's. At first I thought I maybe had to fit a larger master brake cylinder (because I thought that I had more travel because of maybe more pots/volume in the large calipers, but that feeling went away in a week or so.
You did put the correct caliper at each side? so that the bleed nipple is at the top, not at the bottom? (otherwise you cant bleed properly of course)
