msportpanda
I’m having a bit of a nightmare with a brake related squeal on my Z4M and would really appreciate any advice or insight.
After a spirited drive last month, I noticed some wobbling under hard braking and a new squeak from the front right brake when no brake pressure is applied.
I had to replace the NSF calliper last year as it was seizing, so replaced the OSF this week as I thought it may have started to go.
It’s a single squeak noise as the wheels turn and the frequency increases with speed. It disappears when I lightly press the brake pedal, it also randomly stops squeaking (sometimes after a bump).
New front pads and discs were fitted less than 500 miles ago.
The brake lines are all original. My mechanic doesn’t believe in copper slip on the back of the pads when installing.
Could either of those things cause the squeak and brake dust?
