brake sensors
deka
Need to replace the rear disc's, I have bought the disks and a new set of pads, do i need to replace the sensors as well. I have no lights so the pads are not worn down but you have to replace them when you replace the disks
Just be gentle when removing the clip, not broken one yet but they are a bit fragile.
As pvr says they are very fragile and need a certain technique to get them back in including the small 'U' shaped retainer spring.
Frankly though they are only about £6 on ebay so no big deal and you only need one at the rear (and one at the front)
My brake sensor light is on intermittently, usually when I start the car but disappears after a minute or so.
My brakes were all changed less than 10k ago. Will a sensor change fix it?
