brake piston rewind tool
Pastry
 South East
I want to change the rear pads on my E89 but because of the electronic handbrake (poxy idea that was) you need a rewind tool for the piston? Has anyone bought a cheap one that worked on their E89 please?
Smartbear said:
You don't need a tool, the motor part comes off & you can wind the Pistons back manually :thumbsup:
Are you sure Mr Bear, after taking the callipers of today Stu was sure you needed the tool?
Smartbear said:
cj10jeeper said:
I have this one and used it on countless different brake set ups
Even those that don't need to be rotated, but just compressed are easy with it
http://www.ebay.co.uk/itm/19pc-Brak...692479?hash=item20cc02da3f:g:QkkAAOSwm8VUrv76
I believe the e89 rear calliper Pistons need winding in from the back of the calliper after the electric actuator has been removed :?
Thanks Guys. I'll have a look at the video but either way it is still cost effective for me to change them myself, especially as the callipers are off waiting to be painted :thumbsup:
I use long nose pliers on the rear calipers on my MR2, just hold them against the piston and push/turn slowly. That's always worked for me.
I wound my brakes from behind after removing ebrake mainly because I usually strip the whole lot clean repaint etc.
Always think there is the danger of tearing the dust seal if rotated from the piston face.
I have changed my rear pads few months ago and used that same video, you can use a screwdriver but I have used the tool mentioned in this thread (ebay one) and it makes it a lot easier. the screwdriver option would take you ages to push back the piston.
Just to be completely clear on this for when it comes time to change ours, can you wind the piston in both ways?
Either with the e-brake part attached winding the piston or with it removed and winding from the rear?
I'd say yes, looks like Pastry has left the actuators attached & wound the Piston in from the front :thumbsup:
I used the method shown in the video using a large flat blade screwdriver. With hindsight I would have bought the tool as it's only a few pounds and would make the job a lot easier with much less chance of damaging something.
For this reason I always buy s tool. Used it in BMW, jeeps & Jags all with different set ups and so much better than messing with screwdrivers and g clamps
This should be possible with ISTA-D.
I have read somewhere else that there is a software procedure for releasing the ebrake.
EDIT: Found it. It's part of ISTA-D, under Vehicle Management >> Service Functions >> Chassis and suspension >> Parking Brake >> Worshop mode > "ABL - Parking brake: Workshop mode"
I think BMW use a special tool for manually retracting it now but before that tool came along they used the above method.
