Pipes or hoses? Hoses can be bought off the shelf. The pipes can be replaced with a copper alloy. Not sure how you spell... should be easy enough to find via a search. Off the shelf as well, eBay, euro car parts, etc
Choices are copper or Kunifer or even steel rolls of replacement pipe such as this
https://www.ebay.co.uk/itm/393978833899?hash=item5bbaf7ebeb:g:mJwAAOSw205iKKas
Replacing the flex hoses all around for stainless braided is also a good move in particular the rears to get rid of the hard line between the two flex hoses which tends to corrode quite bad.
Decent flaring tool is also a good investment.
I bought Cunifer (Copper-Nickel-Iron alloy = Cu-Ni-Fer) and all the tools last year and taught myself how to cut, bend and flare; then replaced 70-80% of the original corroded steel pipe on my car. A straightforward job if sometimes a little fiddly, but ultimately very satisfying also
