Hi all
Sorry if I'm covering old ground but I need some advice ref New Brake pads.
I want to change mine front & rear and after reading various threads I'm more confused than ever.
I've seen Brembo, Pagid, Bosch and others all for sale on Eurocarparts & Carspares4less, all at a reasonable cost but I have now read that ATE are BMW OEM? and are of course £14 more expensive per pair.
So my questions are as follows:-
1) Are any of these makes ok / compatible for normal road usage.
2) The ATE only seem to be available for the fronts from the sites listed so don't want to mix front and rear really!
3) Will I need to change or renew the fixing clips.
4) Will I need to replace the wear sensors. (The brakes have not worn down to the level where these have been actuated yet)
Any advice gratefully received.
Cheers.
Cheers.
