Hello,
After getting my Zimermann drilled rotors I am now looking for a set of brake pads. For the front I am going for Ferodo DS Performance and Rear Ferodo DS Premier brake pads (Peroformance don´t come for the rear). My only question is what are the correct dimensions for the FRONT and REAR for a 2,5i.
Some of offered FRONT pads are:
Length 151 mm Height 57 mm Thickness/Strength 16,4 mm Appr. stamp E190R01174/003 Weight [g] 1,4 kg Fitting Position Front Axle
other is:
Length 150 mm Height 57,5 mm Thickness/Strength 17,8 mm Appr. stamp E190R0174/003 Weight [g] 1,4 kg With accessories With piston clip
So which one is the right one???
other is:
