Does the clutch have to be bled when replacing brake fluid?
No fluid in reservoir as ABS pump is being repaired.
I want to be able to get enough brakes/clutch to get to local dealer for Proper bleed using correct software etc. I have a pressure bleeder.
The reservoir contains two parts, one for brake, one for clutch. If you do not touch the clutch it will not be needed to be bled.
I spent an hour bleeding the clutch after replacing a CDV until I discovered that the compartment consisted of two parts and the clutch part was empty (but brake part was full :headbang: ).
If you have a soft pedal, just go out and stomp on the brakes a few times to activate the ABS. This will release all the air in the system so you can then re-bleed it. No need for expensive trips to the dealer
No need to use software to bleed the system. Just use the old-fashioned method of getting someone to pump the air out until the pedal's firm. Presumably you only emptied the reservoir via one caliper (FR), so the other lines will still be full of fluid. Bleeding should only take a few minutes.
You still have to bleed the brakes as normal. The problem if you let the fluid run too low/dry is that air gets in the ABS system and the only way to get it out is by activating the abs module, either by using a computer or as I said get it to kick in with some heavy braking.
Pressure bleeders are great if your replacing fluid but not so great if the system is dry.
