hopz121 said:
Yep that’s fine and the normal fluid to use.
Unless you are tracking the car any dot 4 should be ok
...and a lot of DOT4 fluids will out-perform DOT5.1 fluids...just that they haven't bothered spending thousands getting them re-tested...and thus aren't charging a premium for them
For example ATE DOT4 200 'Superblue' (blue dye has now been removed I believe) has a dry boiling point of around 280ºC and wet boiling point of over 198ºC (DOT5.1 specs are >260ºC dry and >180ºC wet)...ATE's SUPER DOT 5.1 fluid is 265ºC dry / 180ºC wet.
Remember DOT5 fluid is silicon-based and is NOT compatible with 3/4/5.1.
