Brake Fluid Change - Bleeding
Exactmax said:
Thanks for your help 'Sam1832' - just what I needed :D
Thats ok
If you had said this the other day I would of took you some photos I only done mine Saturday
If you can wait till Friday my new calipers come, and I can take you some photos of them. Bleed nipples and how to attach the one man bleed kit if you want
Sent from my GT-I9300 using Tapatalk 2
sam1832 said:
Thats ok
That would be fantastic - thank you :D
Exactmax said:
sam1832 said:
Thats ok
Bear with me I only bought them today I was told they will be here for Friday so hopefully I can post you some pics up
Exactmax said:
BMW Redhill wants £104.50 for the break fluid change :(
Try here http://www.maindealerdiscount.com/search and remember you are after the value brake fluid change,,, should come in around 60~£ still would check out the indi's
Is this the right stuff to get?
http://www.opieoils.co.uk/p-741-castrol-brake-fluid-dot-4-formerly-response-dot-4-brake-fluid.aspx
i would say get a friend or mrs to help you, only 2 commands - up - down
easy peasy job
Yep
Here we go
So this is the drivers side caliper, the right hand side is the front of the car
This is the top of the caliper, see the black plastic cap? The bleed nipple is under that
Flick it up
No get your one man bleed kit
Push the black rubber hose over the nipple
Slide the white plastic retaining clip over the nipple
Use a spanner and undo the bleed nipple half a turn
Open the bonnet remove the cap from the brake fluid resivour, and top it up with your new fluid
Jump in and press the brake peddle to the floor let it up
Look at the clear hose you should have fluid in it
Press the peddle 3-4 times to get all the old fluid out you should notice the new fluid by change of colour in the hose
Ensure the resivour never runs out of fluid keep topping it up
That makes it so nice and easy to understand - thank you. I ordered my turkey baster, one man bleed kit and brake fluid today so that will be next weekends work... :D
I wouldn't of thought it would matter too much
As it's all being pushed out by the pressure from your foot
The only thing you will struggle with is getting the level correct with it on a slope
