Brake fluid change 3.0si
doofus4000
Active member
Going to change by brake fluid on the 3.0si..done this before but not on a car with the hydraulic clutch running off the resovoir. For those people who change their own brake fluid..after bleeding the 4 corners is there anything else you need to do regarding the clutch?
I found this guys how-to on a brake fluid change
http://www.z4-forum.com/forum/viewtopic.php?f=12&t=1481
not sure if hes bled the clutch because hes done the CDV delete mod or because you have to.
thanks
