Brake Caliper Refurb
scousefly
Sheffield, Halfway
Im thinking of doing mine as im replacing F+R discs and pads. The calipers are currently that unique BMW rusty colour and whilst they should not take to much elbow grease to get ready for painting Im a bit stumped for what to use paint wise.
Im not keen on a spray paint like Foliatec as they sometimes dry funnt plus overspray alert :thumbsdown:
So what are the recommendations? Hammerite?
Help and advice appreciated, and yes I did a search and trawled through lots of posts so if your gonna use this as an answer :thumbsdown:
Halfords do calliper spray paint. If you're going to do them in situ then mask off the entire wing and suspension. It is very simple :)
The calipers need to be completely clean and grease free, I would use a specialist Brake caliper paint and use a brush. This paint needs to be heated (by using the brakes) to set properly so be careful with it initially. I've used Halfords caliper paint and a two part epoxy paint - the Halfords stuff is so much easier.
Andi.
I've used smoothrite in various colours on my last 3 cars and proper caliper paint on 1. The smoothrite was just as good if not better due to quicker drying time.
I did next to nothing in terms of prep in every case. Just gave the calipers a quick clean with a proper brake cleaner. First time I did the job I set out with a wire brush but it seemed like bloody hard work. The results have always been very good with 2 coats of smoothrite or hammerite smooth if that's what it's called.
Benny88 said:
Putter Whore said:
I used Hammerite Smooth and a paint brush. Very simple. Looks great IMHO.
+1 exactly what I used on my previous car, gives a great finish that lasts too :thumbsup:
+2 I removed the caliper & pads and seperated the two parts but left the piston side connected and hanging from some wire. Cleaned them up with a small wire brush & lots of Wynn's brake cleaner and gave them two coats of smooth hammerite. The finish was really nice and it seems to be lasting pretty well - the brake dust washes off really easily.
Recently painted mine with hammerite.
Done all my previous cars the same way.. Just clear them, maybe a light rub with sand paper, and 3 coats of paint, leaving 15 mins between coats.
Allow 24 hours to harden. Takes about an hour per side.
I have used hammerite and halfords calliper paint both have given good results. If I had to pick I'd use hamerite mainly because it seems to dry so quickly as mentioned above.
Hammerite will do the job :) But when it warms up it will get tacky again and brake dust will bed in over time giving a dull finish. It needs to go off properly which is what proper calliper paint will do :) I used VHT paint on my Evo's brakes when i re-furbed them as the temperatures they were getting to was mad.
