Brake caliper paint colour
Poll Poll What colour caliper
  • Blue
    Votes: 13 33.3%
  • Yellow
    Votes: 5 12.8%
  • Silver
    Votes: 8 20.5%
  • Grey
    Votes: 10 25.6%
  • None of the above
    Votes: 8 20.5%
  • Total voters
    39
What sort of paint did you have to use? Was it just wheels off or calipers too? Did you have to prep them much before painting?
jamesgarbett said:
I used hammerite smooth.. 8 quid a tin, calipers left in situ with a bit of masking on the pads and on rubber grommets etc, prep wise just a wash down first then a good scrub with a wire brush and using some brake cleaner, you'll spend more time on prep than painting, couple of half inch brushes and i also bought a cheap fine artist brush just to get into awkward spots where i didn't want any excess paint getting on, very satisfying days work :thumbsup:
Silverstar said:
You are a bloke with good taste as I see you went with my suggestion :rofl: :P Looks great! :thumbsup:
Indeed buddy, that pic you put up kinda sealed it, had to spend a bit of time finding the right gold as there seems to be some odd shades kicking about but the hammerite is spot on and as an added bonus cheap as chips at 8 quid a tin :thumbsup:
Which one of these on a white Zed
https://www.ebay.co.uk/itm/HYPERGREEN-BRAKE-CALIPER-PAINT-METAL-STEEL-High-Temperature-DIRECT-SHINE/264961451638?hash=item3db0eee676:g:EesAAOSwSYVfx8X5
https://www.ebay.co.uk/itm/METALLIC-PEARL-VIVID-PURPLE-BRAKE-CALIPER-PAINT-METAL-ENGINE-High-Temperature/162112270852?hash=item25bea4f204:g:HRkAAMXQgb1RQKzB
https://www.ebay.co.uk/itm/MITSUBISH-AQUA-BRAKE-CALIPER-PAINT-METAL-STEEL-ENGINE-High-Temperature-125ml/254645680391?_trkparms=ispr%3D1&hash=item3b4a10b907:g:CuUAAOSwVLNfAwjw&amdata=enc%3AAQAFAAACgBaobrjLl8XobRIiIML1V4Imu%252Fn%252BzU5L90Z278x5ickkrDx%252B2NLp21dg6hHbHAkGMf1jpDfAnfB27fBtkJTmjT6RK7BTTxGa8ZAY3%252B8Ga9B0JRiFIskGuN2TUQIFgvDOmIUDGz7ZbfdKPHSn7thQBM9s%252BM%252Bka7Rv8bpy1MR8BXE%252BSVK8olnZV7PdFD4RzD4Fh%252BLeudPZTtEdk2OorBAmoP5yiPt6d18ungfW2vUeHgenO2z5uw3So6Vle6jCjqwyfRadx%252FZshJw1fJxo%252F65zKKYBPcDhP1b3QK3ds5nClYxE6JQtAkf%252FtNT%252BSOs2aVppAg2wx7KeDPv6UA5ybWWY%252ByKXO6Uw6Ko1F9dYD4keGTFyMZNgm2ejUTg6REi7gZxDLic6K0xfQ8l%252FZafOaWfnFu7Z2eNG1fMQyV9%252FxzGsPuaaVU8Pp3qNI6KwLWGNR0EaW52IO8q8lDmfUEdkblk5aQcCqMLrtuLKe%252F7UCavwTiiUTMj7R5CNbrVUhxqrvYfyYnITFGojo8r88QKSKzinMIIYn0ipirxEvTLPCq6vCjDKkfEnjMwkK4Y7%252Bg4rg7U8b5KKsHcupLbk1F5CWw%252BN0pq9QygQdk4JrJYC8CIGb%252F7%252Bg4sB%252BCW5XWk5ZclikRSu1BNruoLTdZVBkyEEKydYf4oWZAfn4l11GBZhFCp3T7jEs0nBw5FzhdManCBP6Dq4R5nQ0kRAOjftv0ppRwnHOR8e3ZtMcugyNPjf6AwRjySelhx5koEIj2SBGie8wZQAqjfp0qXHcuKIeDYZNXP7IF04T8dV%252FkEzWg57525uCvH4B2%252FxN98xXZCFdk42Y2x1XXV19Dpxhia2MUaXbj3EvkQ%253D%7Ccksum%3A25464568039170f6b11bc52a4d1998e501230b76b6d0%7Campid%3APL_CLK%7Cclp%3A2334524
https://www.ebay.co.uk/itm/TechniQ-250ml-Brake-Caliper-Paint-LAVA-ORANGE-260-C-Temperature-Resistant/223471021819?hash=item3407e92efb:g:GowAAOSw8fpcpSTm
Almost anything will go with white but out of those choices I would probably go for the hyper green or metallic purple but if you've got a red interior then I would go candy red.
I like the bright colours, there was that white e89 on here with lime green edging on it a few weeks back, looked ok as a colour, may go for the orange
