Hi all,
Since I bought my Z4M, I often have a problem on track, when I quickly brake after a long acceleration. The brake pedal is very firm, same as if there was no (or very few) brake boost. That's quite frightening...
It happened with original brakes, but after I replaced them by AP-Racing (front & rear) too. So it's not related to pads, fluid, calipers or discs.
I did a simple test : engine on, when I push the throttle pedal and pump 2 or 3 times on the brakes at the same time, after then there is no boost at all. Does it happen on your car too ?
I checked on the ETK and the "air shut-off valve" reference number has changed in 2007 : http://bmwfans.info/parts-catalog/E86/Europe/Z4_M3.2-S54/L-N/browse/engine/vacuum_control_engine/ . Do you know if my problem will be solved by replacing mine with that "new-referenced" part (my Z production year is 2006) ?
If you do the previous test I did, can you please tell me the result and the production year of your car too ?
Many thanks in advance for your help !
