Hello,
I just changed my rotors and pads. I am working on flushing my brake fluid. I bought this European Power Bleeder - Motive Products 0100 kit and am using Motul 660.
Before beginning I used a baster and took out the old fluid in the reservoir in the engine bay. Then I filled it up with the new fluid.
I then put the rest of the new fluid inside of the Motive Power Bleeder.
I pressurized the system to 15 psi and my friend opened up the bleeder valve at the passenger rear.
The pressure in the system held for more than a minute when testing just to make sure.
The brake fluid initially started coming out smoothly, and then it had a bunch of air coming through. The stream effectively stopped. I then went into the car and pumped the brake pedal a few times and it helped and continued. But this entire time we noticed air was coming out of the bleeder valve.
We see air pockets in the Motive Product as it goes in and air at the bleeder valve.
We're super confused on what to do here so any help would be greatly appreciated.
As we bled, the pressure of the air came out and it dropped, I then pumped it back up (Motive).
One thing I did notice was that it was dropping brake fluid at this conjunction that I had to connect following the Motive guide. (Please see Picture).
Additionally, when I depressurized the system to post this, the reservoir tank was super full when I unplugged (literally at the brim!) Is that normal?
Any help would be super appreciated!
