So I have tell tale signs of an oil leak, drips on my drive and a very moist undercarriage. Removed the undertray to be greeted by a mixture of old sludge and mud, thanks to the off road test by a previous owner.
Anti roll bar, steering rack, frame around the area grim. The front of the engine surprisingly dry. Looking towards the right side the engine mount and whole side of the engine covered in fresher stuff. The oil dipstick receiver a bit wet but nothing much, nothing behind it. Removed the air box, alternator dry, oil filter lid secure and dry.
Tightened up the fairly loose oil drain plug ( could it be that easy?!)
Havent removed the intake manifold, could an oil leak be coming from there?
I Suspect the oil filter housing gasket, engine coming up to 150k so due a change anyway. Open to other suggestions though.
Would I see oil up the side of the engine with oil pan gasket leak?
