Boot water leak
daveylad
New member
The other day while out in my 2003 z4 the speakers started to crackle. I thought nothing much of it at first then it got slowly worse. I open'd up the boot and took out a couple of jackets which were wet through. Anyway i pulled out the cover over the battery to see the battery and the very expensive amp swimming in water. I couldn't believe it and wondered how or where all the water got in. I took the battery out and sponged the water out very carefully. I then dryed it out and took the extension lead out and plugged in the hair dryer and gently on a low heat did the best i could to dry out the amp. I re attached the battery and hoped for the best. I then turned on the car radio and was disappointed to hear the dreaded crackling and very unhealthy noises coming through my speakers.
I left it for a day or two and then went out for a spin. I turned on the radio and luckily for me no noise from the speakers and everything sounded as it should. :D :D I think i may have been very lucky in the fact that i just caught it before i cooked the amp.
Now all i have to do is cure the leak. Umm, i did find a slight crack in the third brake light lens ?
Few on here have reported leakage in the boot area, IIRC it's linked to parking nose-up on a hill/incline?
Worked for me :thumbsup: ever since I've started backing onto my drive so it is nose-down my boot has remained dry and I tried for ages with a watering can to try and find where it was coming in
Hi, I have had this problem a couple of years ago. The water appeared to be coming in on the inside the top of the rear wing. In desperation in squeezed silicone grease between the soft top rubber seal and the body. It has been dry since then. when looking through how to remove and refit the softop, it said use silicone grease between body and the rubber seal.
