Description from WDS:
Fully automatic convertible top
The fully automatic convertible top is a folding top fitted as an option.
The soft top is opened and closed hydraulically. When closed, the soft top is locked on the window frame via catches. The catches are driven by means of an electric drive. After opening, the soft top is stored in the convertible top compartment and locked in place by the catches.
Brief description of components
Convertible top module IV (CVM IV)
The convertible top module (CVM IV) controls and monitors the hydraulic and electrical drive and locking components of the folding top. The convertible top module also monitors the convertible top switch, the hydraulic pump and the locking drive, and saves any faults that occur in the fault memory.
The soft-top module is connected to the K bus.
General module
The power windows are contolled during soft-top operation by the general module of the central body electronics (ZKE). The general module therefore receives the information 'Open/close top' or 'Top complete closed' or 'Complete open' across the K bus.
Instrument cluster
The instrument cluster provides the convertible top module IV (CVM IV) via the K bus with the information 'Outside temperature' and ”Vehicle moving” or ”Vehicle stationary” (speed greater than/less than 4 km/h).
Exchange of information is across the K bus.
Hydraulic unit
The hydraulic unit creates the hydraulic pressure required for the top movement. The hydraulic unit consists of an oil reservoir that has an integrated pressure pump. All the hydraulic valves are integrated in the hydraulic unit. The hydraulic system is a closed, self-venting system. Topping up hydraulic fluid is not required.
The pressure pump is driven by a reversible DC motor. To change the direction of movement of the folding top, the direction of rotation of the pump motor is switched.
The pump ony operates in the case of top movements. To prevent damage, the hydraulic unit is monitored by an integrated temperature sensor. At a temperature of 105°C, the pump in the hydraulic system is switched off. The soft top can then only be moved by hand.
Hydraulic rotary drives
The soft top is moved in two directions by dual-action hydraulic rotary drives for opening and closing. Here, the racks of the hydraulic cylinder engage in pinions that convert the longitudinal movement of the hydraulic cylinder into a rotary motion. The pinions transfer the rotary motion across the main bearings to the convertible top frame. The hydraulic rotary drives are fitted on the left and right in the main pillar on the main bearings of the convertible top frame.
Soft-top locking mechanism
For the soft-top locking mechanism, there are two catches which are opened or closed by an electric motor.
When closed, the soft top is locked on the window frame (cowl panel) via catches.
After placing in the convertible top compartment, the soft top is also locked in place by the catches.
In the event of an electrical function failing, emergency release is possible by hand.
Convertible top switch and condition indicator
The convertible top switches are fitted in the switching centre in the centre console. There are separate switches for opning and closing the soft top.
For the display of the active and/or receding state, red and yellow LEDs are fitted beside the convertible top switch:
The red LED lights up while the top is moving. When one of the final positions is reached (top stored in the convertible top compartment or locked on the cowl panel), it is switched off. The LED flashes when the convertible top switch is released while the top is not in one of the two final positions.
The yellow LED lights up when the convertible top switch or the convenience function sends a request for opening while the convertible top compartment floor is not down.
Hall sensors
In order to detect the convertible top position and the two final positions of the locking mechanism, non-contact switches (Hall sensors) are used. The Hall sensors for identification of the convertible top position are fitted on the right-hand main convertible top bearing. The Hall sensors for the cowl panel lock are located on the cowl panel lock in the front convertible top bow strut. The information from the Hall sensors is processed in the convertible top module IV (CVM IV).
Convertible top compartment floor switch
The convertible top compartment switch is an earth-switching contact that generates the signal ”Floor down” when the convertible top compartment floor is located in the lowest position. As long as this information is not present, the soft top cannot be unlocked and opened.
The convertible top compartment floor switch is fitted on the folding mechanism of the convertible top compartment floor.
Hardtop locating points
Contact plates are fitted in each of the two hardtop locating points at the main convertible top bearings. Each contact plate has a contact for power supply of the rear window heating and a contact for hardtop detection.
Main functions
It is possible to open / close the convertible top by means of:
•Convertible top switch (open and close)
•Convenience closing and convenience opening
via door lock or remote control (coding-data-dependent!)
The following conditions must be met at one time for automatic movement of the top:
1.General module can lower the window without faults
2.Vehicle standstill (v < 4 km/h)
3.No hardtop fitted (only applies to closing)
4.Ignition key position as of terminal R (not in the case of convenience function)
5.No short circuit and no breaks in wiring present
6.Outside temperature has not fallen below limit value
Opening the top with the convertible top switch
Pressing the convertible top switch for ”Open top” opens the soft top according to the following sequence:
1.Windows are lowered (power window activated for 1.5 seconds if one window is detected as closed).
2.Lock hooks are opened. The convertible top is unlocked at the cowl panel
3.The convertible top is moved backwards
4.Convertible top is stored in the convertible top compartment
5.The locking hooks are closed
6.The top is locked in the centre in the convertible top compartment
7.Red LED goes out
8.Windows are raised (2 seconds after locking)
Closing the top with the convertible top switch
Pressing the convertible top switch for ”Close top” closes the soft top according to the following sequence:
2.The locking hooks are opened and the catch in the centre of the top is released.
3.The convertible top is lifted out of convertible top compartment
4.The convertible top is moved forwards
5.Locking hooks are inserted in the cowl panel
6.The locking hooks are closed and the top is locked at the cowl panel
7.Red LED goes out
NOTE: If the convertible top switch is released during closing and opening, the movement and locking of the folding top is interrupted immediately. As there is no blocking of the drive, only the self-regulation system of the mechanical system and the hydraulic rotary drive have an effect. Pressing the convertible top switch again restarts the stopped movement.
Convenience opening/closing
The driver's door lock opens or closes the top in the following sequence:
1.Insert the ignition key in the driver's door lock
2.Turn the ignition key to the right and hold in this position
The general module (GM) immediately sends the telegram ”Convenience operation” to the convertible top module IV (CVM IV)
3.The remainder of the sequence is the same as for ”Opening the top with the convertible top switch”, Steps 1 to 7.
4.Turn the ignition key to the left and remove
NOTE: Closing with the driver's door lock (convenience closing) is no longer possible as of terminal R.
Heated rear window (demister)
As long as the soft top is locked and terminal R is on, the convertible top module IV (CVM IV) provides a signal for control of the rear window heating.
Power supply for the rear window heating of the soft top comes from the convertible top wiring harness. If the hardtop is fitted, the power supply for the rear window heating is by means of contact plates on the rear hardtop locating points.
Hardtop detection
If a hardtop is fitted, a contact that closes to earth generates the signal ”V_SPERR” which blocks the ”Close” function.
Storage locking
To release: On completion of an opening procedure, the soft top is stored in the convertible top compartment and locked in place. As interlock, the central locking lug of the cowl panel lock engages in the retainer on the convertible top compartment.
To close: At the start of a closing operation, the cowl panel lock is operated first. Here, the centre locking lug of the cowl panel lock is moved in. This disengages the mechanical interlock.
Cowl panel lock
Locking and unlocking the folding top on the cowl panel (upper window frame) takes place electromechanically with the cowl panel lock in the front convertible top bow strut. To this end, there are locking hooks on the left and right of the cowl panel lock.
For closing the folding top, the locking hooks are closed and locked after entering the cowl panel.
The rotary motion of the spindles of the cowl panel lock required for opening and closing is generated by a direct current motor with angle gear. The direct current motor with angle gear is located in the centre of the front convertible top bow strut. The rotary motion is transferred via flexible shafts.
Emergency closing / emergency opening
In the event of failure of electrical and/or hydraulic functions, the top can be opened and closed using emergency unlocking/locking systems.
Emergency closing:
1.In the luggage compartment on the left-hand side below the convertible top compartment floor, pull out the plastic ring attached to a Bowden cable as far as it will go.
2.With a 90-degree turn, lock the plastic handle in this position.
In the hydraulic unit, a short circuit is enabled, making it possible to open and close the folding top by hand.
3.Pull the handle of the Bowden cable in the rear panel of the luggage compartment.
The interlock in the convertible top compartment is released.
4.Move the top forwards by hand until it reaches the cowl panel.
5.Take the Allen key from the on-board toolkit.
6.Remove the plastic panel from the front roof brace.
7.Insert the Allen key in the uncovered internal hexagon.
8.Lock and unlock the cowl panel lock by turning the Allen key.
9.Take out and replace the Allen key.
Emergency opening:
1.Perform steps 1 and 2 as well as 5 to 7 from 'Emergency closing'.
2.Unlock and open the cowl panel lock by turning the Allen key.
3.Take out and replace the Allen key.
4.Move the top backwards until it reaches the convertible top compartment
