Hi guys, after a bit of advice please.
Have had a problem with the bonnet release on my z85.
Basically it wouldn't open!
Today I got it open, removed the mechanism, deep clean with brake cleaner and an old toothbrush. Re lubricated with copper ease and reassembled.
Got it working correctly when off the car but the main latch spring in the wrong position. This was intentional as with it in the right place the forces appear to be too big????? Re assembled with the springs in the right place and it worked!
Got it working correctly when bolted in, using a screwdriver to set it in the locked position.
Reassembled everything and tested, and it worked. Tried again and it didn't!
Arghhhhhh.
The cable pulls okay but doesn't seem to pull far enough. Is it possible or known for either of the cables to stretch? I also checked the jointing sleeve behind the drivers headlight and this seems fine.
Thanks in advance.
Arghhhhhh.
Thanks in advance.
