Hi guys, got an issue on my 3.0i m54 E85 in that around 3.5k rpm the power seems to dip and rev lags then picks up again, power in 1st seems low but otherwise no noises, idling well and generally running fine. I have changed the Vanos seals around 4k miles ago and sorted the disa valve with upgraded flaps. I have also changed the coil packs and spark plugs. I originally thought it could be the vanos or solenoids as I have not cleaned the solenoids but at the time had no issues so was changing the vanos seals as a preventative maintenance job, any ideas what it could be, don’t want to start stripping components and going over stuff I have done previously if anyone has a better ideas, camshaft sensor maybe?
