For Sale Bmw Z4 Coupe 3.0si e86 2008 Manual Montego Blue
This car is well known to the Z4 forum and has undergone significant refurbishment and restoration detailed in the link below. Its an absolutely fantastic car with great Service History and maintenance. (Please click below link as a previous owner made that car stunning)
Why I am selling such a great car then ?
I always wanted 911 that was my dream so decided to sell z4 and put money towards that project . I will still stay with Zet community as I am looking for z3 for my wife
Have I had any problems during my ownership ?
Absolutely nothing from day 1 car was perfect. No leaks no unwanted noises all electric devices works perfect .
Its an old car any rust on the car ?
Absolutely no rust or bubbles on archers sills etc . .
Where can I vew car ?
Nottingham . car is ready for test drive .
What makes that car drive special ?
LSD in Z4 transformed the vehicle with dramatically improved handling and acceleration.on top of that BC coilovers made ride firm with no crazy bounce .Perfect car for B roads .
Great opportunity for someone to acquire a well sorted coupe who can just get on and enjoy driving it
Modification List installed by previous owner (Lucas)
The handling mods are complemented by new suspension bushes, wishbones and steering arms (all Meyle HD and/or Lemforder items).
路 Fully refreshed suspension bushes, wishbones & steering arms.
路 All oil gaskets have been replaced - Oil cooler, Sump, Cam Cover & Valvetronic.
路 New Auxiliary Belt & Tensioner
路 New Expansion Tank & Coolant refresh
路 New Eccentric Shaft Sensor
路 Fully rebuilt shifter mechanism with OE parts
路 New front and rear badges
路 New coil packs & iridium spark plugs
路 Engine oil change every 5k miles or less with high quality fully synthetic oil and filters
路 Recent fluid changes - coolant, oil and brake fluid.
路 Varta Battery in 2019
路 Starter motor in 2019
Main factory options:
路 Montego Blue paint
路 Individual Champagne Interior
路 Piano black dashboard
路 Manual gearbox
路 Sport specification
路 Heated seats
路 Cruise control
路 Rear parking sensors (PDC)
路 Xenon lights (automatic)
路 Auto wipers
路 Multi-function steering wheel
路 Bluetooth phone pairing
Service History and Preventive Maintenance
16/07/23, 114861 Miles - Oil service, brake fluid, cabin filter, air filter cleaned.
15/02/23 113840 Water pump preventive maintenance replacement (Pierburg)
04/09/22, 111713 Miles - Oil service, brake fluid, cabin filter, air filter cleaned.
06/02/22, 109078 Miles - Coolant expansion tank, coolant flush
09/01/22, 108714 Miles - Spark plugs, eccentric shaft sensor, cam cover & valvetronic gaskets.
28/08/21, 106972 Miles - Oil service, brake fluid, air filter cleaned.
08/05/21, 102197 Miles - Oil service, brake fluid.
13/02/21, 99400 Miles - 6x Bosch Ignition Coils
30/10/20, 96468 Miles - Sump gasket, oil service.
23/07/20, 93135 Miles - Oil service, brake fluid, air filter, gearbox oil & differential oil.
24/11/19, 86563 Miles - Oil service, oil cooler and oil filter housing gaskets, auxiliary belt + tensioner
17/08/19, 83670 Miles - Oil service, spark plugs, cabin filter, air filter.
26/05/17, 74318 Miles - Oil service.
16/07/15, 62604 Miles - Inspection 2.
20/09/13, 50303 Miles - Oil service, brake fluid, air filter.
06/10/11, 36282 Miles - Inspection 1, brake fluid, air filter.
16/09/09, 17084 Miles - Oil service, air filter.
27/03/08 - Pre-delivery check
The bad bits:
Current Millage
115100
Price is SOLD
- ZHP knob installed
- 108s wrapped in Goodyear Eagle F1 Asymmetric 5s
Changed kidney grills for OEM black ones w/ chrome surround
M-Sport seats restored + full interior detail
Fixed ash tray lid & door card
Gave fog lights a light refurb and installed LEDs
Full engine detail
Lambda sensor (Bank 2 Sensor 2) replaced
CDV Delete
Grom BT-3 installed
Static short number plate installed (these are removable for shows)
Headlights sanded & polished with AutoGlym's Headlight Restoration Kit
Bi-Xenon projectors removed from headlights and cleaned
Calipers painted in Graphite Grey
M-TEC Drilled Discs and Greenstuff pads installed
Interior cable management w/ QC3.0
Replaced starter motor
De-badge
Change Valvetronic Motor's gasket due to an oil leak
Inspection 2/Full service
Bilsteins B4s w/ Eibach Pro Kit Installed - No longer in the car.
Eibach Pro Spacers (12 fronts, 15 rears)
Exhaust mod
4-wheel alignment (CSL geo)
Morimoto Mini 5 Bi-Xenon Projectors customised for OEM-like fitment and installed
Replaced boot and front bumper badge
New Centre Storage flap from BMW installed
Steering Wheel Trim restored
Royal Steering Wheel Re-trim and custom gaiter installed
Changed exhaust tips
Oil Filter Housing and Oil Cooler gaskets replaced
Ultralight 3-Point Strutbrace installed
BC Coilovers Installed
Adjustable Rear Camber Arms and RTAB Limiters installed
Wavetrac ATB LSD installed
Front wishbones and steering arms changed (Meyle HD)
Sump Gasket Changed
Sound deadening inside doors and around speakers
aFe Intake
Re-modded Exhaust
EBC YellowStuff pads installed w/ new front drilled discs
路 Wavetrac LSD + new OEM diff bearings and seals (built by Darragh at Everything ///M3)
路 BC Racing coilovers with custom spring rates (on the softer side for coilovers)
路 Adjustable camber arms (no excess camber like most lowered Z4s)
路 RTABs Limiters from Hack Engineering
路 Drilled & coated brake discs, braided hoses and yellow stuff pads.
路 White Line Strut Brace
路 Manual gearbox
路 Heated seats
路 Cruise control
路 Auto wipers
The bad bits:
- * Stone chips in the front end - mostly in the lower front bumper.
*Driver's window scratches (the usual Z4C ones).
*Drivers side rubber door gasket bottom part has crack in one place .very common
Current Millage
115100
Price is SOLD
