robertlancaster1094
flybobbie said:Could later buy the pass through parts and fit, like i did. It is useful.
thanks for the advice ill probably try that as a last resort
Nictrix said:robertlancaster1094 said:are you blind or just ignorant? i stated in my original post on here that i had a water leak and explained everything and also explained why i removed the battery because the rac rescue man that was called out informed me that i would be able to remove itRobbiZ4 said:Well, having forgotten a massive water issue inside of the trunk can be forgotten, of course. :x![]()
Hey Robert, what you are doing there without any knowledge of the car and a mechanic, who doesn't even know anything about the car's electric/electronic system is:
HARAKIRI
Absolute no recommendation to do anything by yourselve with that huge lack of knowledge!!
Search a garage with a minimum of understanding of these full electronic cars to not loose thousands and thousands of bucks with your current "strategy".
E89 are no playgrounds for children.
Yes, the red box next to the battery is a fuse box for higher currents. Even the terminals will be routed through it. Due to the "forgotten" watter issue this box might have been destroyed as well.
This might be an option and can be tried out:
Put the negative terminal of a loaded battery onto earth, i.e. the terminal screw under the hood. But not on the terminal with the red cap!!!
Then you can connect the plus 12V from the battery with a tiny wire into the hole of pin12 of the correct(!) black 54-pole sliding plug taken off below of the junction box. It only needs half a second to get the central locking motor activated.
Making any fault with this operation will kill your car - fullstop.
Poor show. You only joined this forum as you had an issue with your car. Members are trying to help and give you advice and they don't need to be insulted for it.
ThePope666 said:just made an account because i read what you said about this not being a fault of the designers, which good design relies fully on technology to do something as simple as opening the boot but also not having a mechanical backup for it? many things could break that prevent the boot lock from opening electronically not just taking out the battery. It's a bad design and everyone knows it, simply blaming the people for being stuck in this position in the first place when it shouldn't be a problem is extremely stupid RobbiZ4.
Yea, you are right.Nictrix said:are you blind or just ignorant?
RobbiZ4 said:Yea, you are right.Nictrix said:are you blind or just ignorant?
Will drop all my hints. Would be nice, if you'd drop my quotes as well.
Good luck destroying more of this nice car.
One final wish:
Learn to quote in a senseful manner.
One final wish:
Thanks for this excuse and coronation.Stash36 said:He is German and a bit Direct.
No, that is not required at all! No violence. :evil:flybobbie said:...you would have to cut through the bulkhead carpet from the cabin..
Agreed of course, but it's the wrong direction.flybobbie said:Just a suggestion if the person cannot open the boot.
The trim is replaceable, if not up gradable.
Not needed the hole is already there behind the cabin bulkhead trim, just remove the trim.robertlancaster1094 said:i got a mechanic to try everything on it today with the terminals under the bonnet etc and he said im gonna have to contact an auto electrician , also i thought of another idea is it safe for me to cut out the metal panel behind the seats and installing my own ski hatch for boot access
RobbiZ4 said:Agreed of course, but it's the wrong direction.flybobbie said:Just a suggestion if the person cannot open the boot.
To check the tyre pressure, you can also cut it open and measure the volume. They are replacable as well.
It's a valid option.![]()
Stash36 said:Robert you have pissed off the forum roof and electrics expert who has helped many on here and probably saved us 10s of thousands of pounds in roof diagnostics and repair. I suspect you are in a bit of a panic, been there myself, feeling totally out of options
Everything he said was a warning to tread carefully things can go from bad to worse if you take the wrong steps. He is German and a bit Direct.
The good thing, he confirms the pin 15 trick which was linked on the first page of your thread should work, so read up on that.
I have used it myself so ask questions if you need to.
he's clearly got a chip on his shoulder he probs works for bmw or something and helped create this terrible design faultflybobbie said:RobbiZ4 said:Agreed of course, but it's the wrong direction.flybobbie said:Just a suggestion if the person cannot open the boot.
Writing stupid now.
flybobbie said:Not needed the hole is already there behind the cabin bulkhead trim, just remove the trim.robertlancaster1094 said:i got a mechanic to try everything on it today with the terminals under the bonnet etc and he said im gonna have to contact an auto electrician , also i thought of another idea is it safe for me to cut out the metal panel behind the seats and installing my own ski hatch for boot access
RobbiZ4 said:An upgrade to integrate the ski hatch is another topic and not required as a roof repair option.
But to get the trunk opened, only two thin wires are required as far as the rear central locking motor is in a working condition. Ignoring this is a valid option.
