BMW TIS online
enuff_zed said:
Jaydennn96 said:
mac27040 said:
what you after as i can access TIS
Hi,
Do you know if there are any instructions on how to remove the interior carpet?
Thanks,
Jay
Jay, it's simple to get the rear section out, but to remove the front half properly you need to remove the heater assembly as a drain from it runs down through the tunnel. You may get away with lifting the heater a bit but not easy.
If it is to dry the carpet out then I'd suggest removing the centre console, then simply lifting the carpet as high as you can to get warm air, towels etc under it.
This is exactly what I’m going to do, seems like it’s a nightmare otherwise :(
