A
Anonymous
Guest
Just thought I would do an update on this little box fitted to the N20 engined E89s, which sits on the rear bulkhead next to the GSM unit on the LHS.
I disabled mine by using a bypass cable (you can't simply remove it as then your audio system is disabled).
I've done a few long journeys now with several pax, and a common comment from them is how less tiring the car is now that the intrusive drone is gone (not me)..
I noticed now at motorway speeds the only noise is a bit of rear tyre noise and little else with the top up.
Also the sound system, which I spent a lot on is noticeably better as the audio circuits no longer route through the ASD.
It was only when I upgraded the sound system with much better bass that the realisation that the throaty exhaust note was, sasdly a work of fiction..
