Bmcables.com user guide
*jimmyj*
West Yorkshire
Hey guys,
I'm after z user manual for the bmw cables software. Need to turn off my air bag light or at least find out what's up with it.
Any help will be appreciated.
Someone at some point should able to help with the software. A common problem with the airbags is the module you find under the seat. Mine popped randomly after having something done at the dealer - they said it was common fault, so much so they had the spare part in stock.
If anyone knows id appreciate how to use this cable to turn of transport mode?! Bought a cable and not sure which part of the software will do it :headbang:
Transport mode is in SSS, I think in retro section.
Airbag light can be done via DIS or inpa, in DIS do a test then go into module function bottom right, should give you a list on the left of the modules, select each one and read memory then clear memory. Should turn light off unless you have a fault.
Sent from my iPhone 5 using Tapatalk pro
