senwar said:
pvr said:
Not just charging. It also uses the external aerial which is in the rear bumper
Should that result in better signal/performance then?
Yes, it does - well, if you already had 5 bars it's not going to really improve it but if you are driving through patchy areas it will help.
Might be worth holding off - the snap-in adaptors are usually all over eBay at good prices. None there yet, but give it a while.
