I’d suggest the gasket failure over pressurised the cooling system and the pipe was the weakest point and poppedSo....would it seem that your initial hose blowing caused the engine to get hot enough to damage the head gasket??
Is that not what the expansion tank/ cap is for, though??More likely the gasket went, pressurised the system and blew the hose.
Cap is screwed on tight. Would take some pressure to burst the tank before It popped a hose off. I’m not sure it is truly an expansion tank. Those are there to take expanded hot water then syphon it back in as the coolant cools and contracts. What we call an expansion tank is in fact a part of the whole pressurised system. Harking back to my 2.8i Capri, it was in fact termed a degassing tank.Is that not what the expansion tank/ cap is for, though??
Yes but the caps have a pre-determined 'release pressure' as a fail safe for this very reason.Cap is screwed on tight.
I can only speak as I find and I’ve had three other instances on other engines where a head gasket has blown a hose off. Possibly as it produces a localised ‘bubble’ which impacts the hose before it makes it as far as the ‘expansion tank’.Yes but the caps have a pre-determined 'release pressure' as a fail safe for this very reason.
I know feck all about engines but I know a little bit about cooling/ heating systems and pressure/ temperature.
The expansion tanks are just that, which is why they are only ever filled with liquid to around half way. The rest of the space is to allow for the expansion of the coolant at high temperature, thus keeping pressure down.
To 'blow a hose' suddenly (assuming it was sound before) would require very high relative pressure (probably around 5 bar/ 70psi minimum). Car cooling systems are not pressurised by anything other than coolant temperature in a hermetically-sealed system. If they work at more than 20 psig I would be surprised. Water pumps just circulate, they don't pressurise.
Not having a pop, just find it interesting.
How did you know it wasn't the other way around, though?I can only speak as I find and I’ve had three other instances on other engines where a head gasket has blown a hose off.
We can take this around in circles all day long. I've related my experience.How did you know it wasn't the other way around, though?
Once something has 'gone' it is very difficult to ascertain in which order it happened, surely?
A catastrophic head gasket failure to blow a part of the cooling system instantly is surely unlikely? I understood they start to 'weep' first, which give other indications. I would have thought a loss of compression in the cylinder(s) would be first, no?
