Rachel, for the cost of the cap, I would just change it , incase the seal is worn. Febi caps are about £12 or so on ebay.
Rachel!!!! said:Thrustyjust said:Rocker cover caps can show oil by hamfisted people who miss the hole when refilling the engine from top ups or oil changes. I found the same issue as you and cleaned up the oil and monitored and never returned for me.
This could still be a problem with pressure with the ccv which may cause excessive pressure though on yours and oil to vapourise out the cover.
Thanks, a tiny bit has returned after cleaning it up and driving it so it doesn't appear to just be a spillage.
The car isn't using any oil though which seems to be the main symptom usually from what I've found through GoogleDoes this just mean it's not got that bad yet and that's what would happen next if left alone? I topped up with 1 litre in Nov and it's only 1 bar down on the digital gauge and has been for ages.
Rachel!!!! said:I've just spoken to my friend who looked at the car and he's been watching some video's and says from the video you should be able to open and close the disa valve with your hands and he couldn't. Is that broken as well? Would the ccv being blocked have caused it to break? or could this be the issue instead of ccv?
All I will say is I'm learning a lot with this car, I didn't even know what these things were before lol
zriha said:Dropping again, as we have the same problem, so what is the diagnosis? And how to fix it?
Changing the whole oil separator https://www.ebay.de/itm/162995140257?hash=item25f34476a1:gGsAAOSw0TVfPne2 ?
And also Vanos kit - https://www.ebay.de/itm/253750246379?hash=item3b14b17beb:g:huUAAOSwEt9e6dSY ?
Thanks!
Smartbear said:zriha said:Dropping again, as we have the same problem, so what is the diagnosis? And how to fix it?
Thanks!
As already mentioned, the vanos has zero effect on oil burning issues.
zriha said:Smartbear said:zriha said:Dropping again, as we have the same problem, so what is the diagnosis? And how to fix it?
Thanks!
And the oil separator ?
Smartbear said:zriha said:Smartbear said:As already mentioned, the vanos has zero effect on oil burning issues.
Definitely.
Smartbear said:Rachel!!!! said:I've just spoken to my friend who looked at the car and he's been watching some video's and says from the video you should be able to open and close the disa valve with your hands and he couldn't. Is that broken as well? Would the ccv being blocked have caused it to break? or could this be the issue instead of ccv?
Even if the disa valve was solid it couldn’t coat the inside of the inlet manifold with oil, it’s the ccv that’s responsible for that.
Hi, thanks for the update. I must admit I thought the spots looked quite watery. It was mostly water that hit my hand over the exhaust tbh.Rachel!!!! said:Sorry for the delay it's been a busy week.
I spoke to a bmw specialist last Friday, he suggested that if the soot on the bumper is watery and not oily it could just be a condensation issue. He said once condensation has built up from short journeys it's then very difficult to get rid of.
The disa valve was missing the pin and stuck in the open position, this has now been replaced. The mechanic said to change this and see if there was any improvement and go from there as he said it could solve the problem. I'd already ordered the part and my friend did this along with an oil and filter change which has stopped the noise on the oil filter. The noise was only present when revving the engine not at idle.
The oil from the filler cap couldn't be seen until we took the engine cover off. I'm going to check it again tomorrow to see if any has come back since the oil change.
So at the minute it's still up in the air. But I will update again as and when I get anywhere.
Thanks for the offer of help, that's much appreciated, I will be in touch if needed. I was thinking of getting a mechanic onto the job if it is the ccv as it seems like quite a big job taking everything apart to get to it.
Good news.Rachel!!!! said:Quick update for anyone following this.
There's been no more leaking from the oil filler cap and so far so good with the soot on the bumper. Since washing the car last Thursday there hasn't been any reappear. The car has been used much more over the last month including longer journeys. I'm obviously going to keep my eye on everything but![]()
enuff_zed said:Thought I'd just restart this thread as I was wondering if Rachel ever got the car sorted properly?
