BMWZ4MC said:
It sounds like your mate was somewhat overcharged for replacement cams and followers. Did he go OEM or upgrade?
After several forum threads about Z4Ms needing new cams and followers, I asked my Indy what would be the cost to replace both cam shafts and all the lifters in the event of failure. Bearing in mind that he has first-hand experience of doing the job previously, his price was ‘around £1500’. That was about five years ago, so even with inflation it shouldn’t be over £2000 now.
I’m aware of half a dozen Z4Ms that have had new cams and followers, and a similar number that have spun bearing shells. Most were not regular track cars. I think “very rare” understates the frequency of these, but I do agree it is not ubiquitous.
New oe cams - £1,546
New schrick dlc followers x24 - £1476 (oe ones are even more expensive at £107 a pop!)
Fitting (including head gasket): £1580
Not sure where you're getting your costs from but guessing your indy was quoting based on you supplying the parts!
Fwiw it's possible to reduce the fitting cost by several hundred if you don't do the head gasket and instead remove most of the front end to get the follower tubes out. In my case I'd rather have my pistons inspected and know the head gasket is good before bolting it back up and getting on track again.
Also ironically the schrick cams are a couple of hundred cheaper than oe new ones - but when you factor mapping in it obviously becomes a more expensive route again.
