Roadster_Surrey said:What's the cheapest OBD device (available in UK) that works with these programmes?
I paid £45.99 in July for a TONWON vLinker BM WiFi OBD Scanner OBD2 from Amazon
alstrickland55 said:I used Bimmercode to turn off ASD. Doing so also decreased volume from the rear speakers. To balance the sound for listening to music the fade must be set to almost completely shut off the front speakers. I coded ASD back on and the stereo works like it should.
Argyll Andy said:alstrickland55 said:I used Bimmercode to turn off ASD. Doing so also decreased volume from the rear speakers. To balance the sound for listening to music the fade must be set to almost completely shut off the front speakers. I coded ASD back on and the stereo works like it should.
[ref]Scubaregs[/ref], did you experience this when you did yours? I was thinking about it but not if it detracts from the quality of the music playback.
Pbondar said:Bimmergeeks Protool is much much better![]()
Scubaregs said:Argyll Andy said:alstrickland55 said:I used Bimmercode to turn off ASD. Doing so also decreased volume from the rear speakers. To balance the sound for listening to music the fade must be set to almost completely shut off the front speakers. I coded ASD back on and the stereo works like it should.
Never touched that on mine Andy, above my pay grade.![]()
Argyll Andy said:I can’t say I’m that conscious of it on the M40 but roof down almost all the time bit would consider turning it off if it’s worse with the roof up.
Midlife crisis said:Do you know if you can get this in the UK?
Midlife crisis said:Thanks, do you know where you can get the cables to connect your phone to the car?
