I need to put the front end on axle stands but have a dilemma. The only acceptable place I can find to place my trolley jack is under the plastic jack carriers at the front of the sills. But when I jack it up from there, I can't find a suitable place to put the axle stands. I would usually place jack under the front cross member, then put axle stands under the jack pads. But the z has what appears to be an aluminium shield under the rear of the engine which covers the cross member and would get damaged.
The rear of the car I find simple, trolley jack under the two bolts on the diff, then jack up and put the axle stands under the two rear plastic sill jack carriers..
