GuidoK said:So, I can understand that if you know nothing about bmw specs that this looks like a good video, but 'showing something' doesnt make something a good video, especially if there are some pretty big factual mistakes made by the mechanic if you compare them with the official bmw procedures.
Needless to say that the bmw specced procedure is more complicated and more work.
So quite a few factual errors in that video, not only related to the work but also to what the mechanic thinks how things work...
- 1st error: the mechanic thinks the base material of the bearings is a copper base (2.40). It is not. It's steel. Copper is just another layer.
- 2nd error: 5:00 the mechanic says the clearances on the rodbearings are very tight, more than on 'normal engines'....S54: 0.030-0.070mm M54: 0.020-0.055mm (the s54 clearance is way bigger...)
- 3rd error: When fitting new rodbearings, the bmw workshop manual states that bearing tolerance should be checked with plastigauge.
The mechanic totally skips this part!
Plastigauging is done to ensure that the fitted bearings have a bearing play specced to that 0.030-0.070mm tolerance. Both a too tight and a too loose tolerance are not good: the thickness of the oil is matched to these tolerances. Skipping this step gives you no certainty that the bearings are fitted within spec. Bearings could be faulty from factory, but also there could be dirt between bearings and rodpieces. He tries to work clean, which is indeed important but it doesn't give you certainty. To me not doing this is cutting corners (plastigauging all bearings takes time). If he was really meticulously, or if this was an unknown damage, he'd plastigauge both the old bearings (with the old bolts) and the new bearings, and measuring the crankdiamteres to give a complete picture of what was happening inside of the engine.
- 4th error: the bmw workshop manual states that before final fitting the bearings, both bearings and cranksurface should be well lubricated with oil.
The cranksurface: he doesn't oil at all, the bearing surface, he only half lubes it up with oil...No idea why someone would think that's a good idea.
It's general best practice that all moving surfaces are completely oiled before fitting. Any mechanic should know this.
For torqueing the rodbolts, he uses the ARP specs as he uses ARP bolts instead of BMW bolts. But I have some serious doubts about these.
ARP advices to use a stretch gauge, which is a good method. The stretch tension on rodbolts is important. But they also spec that if you don't have a stretch gauge (basically a micrometer that fits around the bolt, and you measure the unstretched bolt and when torquing you're measuring how long the bolt gets, to a certain spec) you can use a torque wrench with just 50ft-lbs (67Nm) in this case.
I think the bmw method is more accurate. One can say that at the 2nd torque in that procedure (30Nm), the bolt starts to stretch.
The 105deg is the part where it stretches to a certain fixed value (with torquing to a certain # Nm you don;t have that fixed value, it is dependant on the friction of the threads). I can imagine that using different bolts (different material?) the stretching value is different.
If you calculate ARP's setting of 0.065-0.070" of stretch to a rotational torque it would be around 60 deg (if the threads dont deform).
Interesting thing is that for the m54, s52, n62 and a whole lot of other bmw engines, that number is 70deg.
I also think it's strange for a professional shop, specializing in tuning and BMW's that they dont have a rodbolt stretch gauge, as it's a cheap tool that can be had in the USA from as low as 50 quid. (the bolts themselves are even more than twice that....)
So imho this guy ignores a number of bmw workshop specs. Making a video about it doesnt make it a good repair. What makes something a good repair is actually following specs, knowing what to do and knowing what not to do. And these specs are all over the internet, so it's not a big secret or so.
So imho this video is pretty slopppy with a mechanic/shop cutting corners.
Nice workPDJ said:I can also confirm it is easier with a garage lift, because I did mine with the car on 4 axle stands, but to avoid oil dripping on me I left it to drip between weekends strip, clean and rebuild.
I did change my post when I saw they were ARP bolts. But ARP recommends using the stretch method. They give a normal torque spec if you don't have that stretch gauge. So not the preferred method. He chooses the lesser method. Would you want that to happen to you're pride & joy because of not having that tool?TomK said:Your changed point 5 - I don't really see how you can give an opinion on this of his work, the mechanic is just following the manufacturer procedure for that bolt in that installation. Is the manufacture wrong?
True, the plastgauge is not the most precise tool, but there is no other tool you can use. And it is a checkup to see if it's within spec. Not to measure the exact amount of play.This is on an S85 so perhaps it is different but he kind of says using plastiguage is a bit pointless...?
No doubt you can assassinate this video too![]()
GuidoK said:But ARP recommends using the stretch method. They give a normal torque spec if you don't have that stretch gauge. So not the preferred method.
We're talking about a professional shop and a £50 tool (half the price of the bolts themselves). Come on, what would you use if you were a 'professional'?
Glad that you doGuidoK said:Selfreflecting I always wonder... am I the only one who sees this?
GuidoK said:I did change my post when I saw they were ARP bolts. But ARP recommends using the stretch method. They give a normal torque spec if you don't have that stretch gauge. So not the preferred method. He chooses the lesser method. Would you want that to happen to you're pride & joy because of not having that tool?TomK said:Your changed point 5 - I don't really see how you can give an opinion on this of his work, the mechanic is just following the manufacturer procedure for that bolt in that installation. Is the manufacture wrong?
If you look at rodbearingsprocedures etc on other coars, you'd see that fitting bearingcaps with just a single torque spec is not common practice. In fact I wouldn't know a single modern engine that uses such a spec. (of course I don't know them all, but I've never seen it).
It's always 1-3 stage torque and then an angle. That is common practice. Either that or measuring directly the bolt stretch.
That's why I really have my doubts to a single torque spec and if that is the non preferred method, I would certainly use the preferred method, and buy the £50 tool...
So not using it, there is no certainty that either fitting of the shells went ok, or that the shells themselves are within spec.
Is that pointless? I don't think so.
To give an example of my own engine:
(these were the used bearings btw, but not that that matters, it was a complete mapping/checkup to see wat 30k miles of supercharged driving did to this engine, and there is hardly any data on this, hence this action)
BMW specs that they have to be within 0.020-0.055mm
You can clearly see they are within that, and that there is enough resolution on the scale to determine that (don't mind the word inches, this is the mm scale).
But again: they are not to measure the exact bearing play, they are to be used to see if somethings wrong.
Rodbearings are very critical and I think a good technician should take the time to check if it's within spec. To me: BMW didn't put that in the workshopmanual in vain. And probably it's unnecessary 99% of the times, but it's for that one time that something wasn't right and the engine turns in a pile of scrap within the first few miles. These things happen.
I may be harsh, but these are supposed to be highly trained professionals...
And you have to pay the shop for it.
Unless they don't profile themselves as top of their field. If their slogan is: we're the cheapest, we guarantee it, and if they are, then everything is fine.
Point 1&2 of course don't affect the work done. But hey, its of course purely coincedence that I find that he's skipping points in the workshop manual, has a contradicting point on lubing to BMW and chooses not to use the preferred method to fit things from a tuner.
Do you know if the one from the s50b30 (also used in the m50 and early m52) is a direct swap? That's still for sale (from a time that the oil pump was serviceable)PDJ said:the condition of the oil pump relief valve
GuidoK said:Do you know if the one from the s50b30 (also used in the m50 and early m52) is a direct swap? That's still for sale (from a time that the oil pump was serviceable)
I've seen ones with a special coating for sale in germany at certain tuners, but I'm not sure where they source the base parts from.
GuidoK said:And what do you mean with "ended up with an external one"?
MichaelK said:Anyone got a picture showing the pipe from vanos to accumulator please? I wondering if mine is leaking. I have slight bit of oil running down behind the pulleys under the vanos. I have read that a 13mm tensioner bolt does come loose however you cant get to it unless you undid and moved the coolant chamber part to the right of the vanos.
My cars going in on 28th April to have road bearings done. Alot of money for no visual difference but it Is nice for peace of mind i suppose.
PDJ said:You can change the rod bearings as many times as you like but without checking the oil pump and relief valve you could be wasting your time and money
It least fit an oil pressure gauge
On start up these engines with 10/60w produce far to much oil pressure so this in part is where the warm the engine up comes from
At the weekend I will try and remember and make a video of the start up and warm up times, pressures and tempretures
It's not an oil pump failure, its the regulator piston wearing.AndyBeech said:Interesting to see in the future as mileage goes up if there are more oil pump failures as there aren't many documented one's so far, certainly not enough to be too worried about it IMO.
GuidoK said:Fitting an oil pressure gauge is a good idea but lets be honest a lot of people aren't going to want to cut a hole in their OE interior to fit a gauge or delete their air vents to do so.
