Best path to run wires?
HJBondar
Re doing the sound system and need to run rca cable from new head unit to new amp in battery well. What is the best path to do so?
Ok, E85 is easy. First remove panel under the climate control buttons, remove ashtray. Remove boot carpet and under the rear wall carpet, in the middle, you’ll find a hole in the rear wall. From there you can feed a wire snake to either left or right side of the centre console to find a route to the ash tray area.
