Yes it does, using the
quadlock harness.
I can't open the attachment.. do I need a login to view it? Where are you supposed to put the connections box (the bit with the USB connector and line in etc) in a Z4, does it go in the glovebox? I quite like the idea of that, I had a Dension before and really liked it, I prefer the way it operates to the DICE.
This is my understanding too, except I don't have a CD changer. It's similar still - the audio still goes to the DSP for processing, and the quadlock socket just controls the non-audio bits (track changing, etc).
I don't have the CD changer either, however the majority of Z4s are wired for the CD changer regardless of whether it is fitted. The DICE instructions for connecting via the CD changer show where to find the cables (you have to open the boot, fold down the firewall carpet and then you can get at the back of the compartment that is between the seats in the cabin - which is where the CD changer would be if it was fitted):
http://www.sixspeed.net/sixspeed/Z4M/DICE Z4 Installation.pdf
What those instructions don't show is the ADC connection (as they are not the instructions for the analogue DSP installation unfortunately).
The reasons to go for the centre console/boot install is so you can have the ipod in the centre cubby and also because if you need the ADC it is just a question of running the wire out of the hole in the firewall and under the boot carpet to the amp - which doesn't require running cables back through the passenger compartment obviously.
But you can't control the tracks from the head unit
Bugger!
That suprises me, I can't think that analogue vs. digital should have any effect on the track changing.
Yeah, had a chat with him over PM on ZPost. He said I'd need the
DICE Trunk Interface Harness for BMW and
DSP Kit for DICE iPod Integration Kits - quite a costly solution if you include P&P at $40 and the price of the Dension Gateway unit itself.
Ahhh, possibly the penny drops... OK, that makes sense, so is he saying that you need to run the connection back to the boot, hook in the ADC and connect to the amp? Or is he saying that cable will allow you to install the Dension in the boot/cubby rather than connecting it directly to the head unit?
If Tom know's that definitely works then I reckon that will be a good solution, like I say I prefer the Dension and I like that you can update it's firmware - having to send the DICE back to the US every time they update the (reportedly buggy) firmware is what has put me off it and made me think about getting the intravee instead (which is even more expensive
, but seems to operate the best and can also be software updated by the owner)
Mind you, I'm not sure how good the Intravee is with a Business head unit, as there is only one line for the display - I need to research what functionality there is with the Intravee and Business head unit.
The biggest problem I found when researching was that not many people know about the issues with DSP. This isn't helped by the fact that the newer Z4s have analogue DSP. It gets too messy - I've started hating the DSP :x
All I want is to connect my music player to the head unit - didn't expect so much grief. :thumbsdown:
Tell me about it, I ended up installing the Aux In over the weekend as a stopgap because I just couldn't get a definitive solution I was happy with!!
The other problem is that all the US based guys will say go for the DICE as it they can send it back to Tom (@ EAS) easily. For us UK based owners, that is not such an easy option.
People have been really helpful though, which is great, gotta love the internet!
