Beep Warning Sensor When Starting Engine
Is Apple Linux based - sorry if this is a numb question. I seem to remember some bloke saying it was?
It operates similarly, rather than using the shitty hybrid kernel system windows use....
Ed Doe said:
I believe it does it when the temperatures start to drop; but I believe it beeps at ~3C, so surely it can't be happening at the minute for that reason?
To add, mine has never done this, but then I never leave it in reverse having parked! I do also start it with the door open with no issue :lol:
Mine has started doing this just today, can only assume it’s related to the cold weather, but there’s also a different 2 beeps for the cold weather warning once the car is started!
So I’ve got 3 beeps, one when I turn the key in the ignition without turning it on, then the normal double beep for cold weather! Very puzzling.
Thank you very much for this perfect written How-To. :poke:
Guys, you made my day. :tumbleweed:
