BC racing coilovers, not too low please
perttu said:
I'm currently looking at 7kg/mm / front, 10kg/mm / rear. What has been your experience on different stiffness settings? Mostly what I'm hearing is that softest setting is close to stock and stiff is really hard.
7 kgs front would be a good all-around choice and you could even consider stiffer if you value front-end sharpness. Ride quality is much more influenced by the rear axle, so you can stiffen up the front considerably without significantly compromising ride.
And you can always swap out the springs later - you can go +/- 2 kgs without needing to revalve the dampers.
I've yet to really experiment with damping settings. On the smoother roads of Europe where I've done most of my Z4M miles I was able to run close to full hard on the front. I've haven't yet driven many miles in anger on bumpy UK lanes.
perttu said:
peteslag said:
Hello all,
I'm definitely going to buy BC racing coilovers but I don't want to lower the car. Before I pull the trigger on a purchase I was wondering if any body on here has BC coilovers set to their highest setting, if so I was hoping you could measure the ride height for me.
I contacted BC racing but they couldn't say with any certainty what the figure was.
Thanks in advance,
Pete
*EDIT* i have my answer, they are height adjustable to near standard height. Thanks for looking.*EDIT*
Came across this old thread while looking for an answer to exactly same question. Pete, if you ended up purchasing BCs, can you confirm if you're able to reach stock or close to stock height with the highest setting? Or maybe your EDIT comment was already based on your own experience after installing the coilovers? :).
Long story short........I put the car up for sale because couldn't bond with it. I bought a VX220 turbo to fill the void. Recently I have started to unravel the peculiar way that the Z4m goes about its business and have found love for it. The VX220 is going up for sale tomorrow.
I know that others will probably disagree but in standard form I feel like there is a disconnect between the front and rear suspension. When the rear of the car breaks traction I can sense what is going on and fix it with corrective steering inputs. When the "drift" comes to an end and the rear tyres start to find traction and I find that it snaps back quite viscously. This might be down to the fact that the dampers are very tired but my personal thoughts are that decent coilovers and a good alignment will fix this.
There is a brutally honest review here, it kind of mirrors my views:
https://www.youtube.com/watch?v=tgATPu4zFOU
As soon as the VX220 sells I'll be fitting BC racing coilovers and I'll get back to you with some feedback. My understanding is that they can provide OEM ride height.
@peteslag I'm in the SE but if we can meet somewhere in the middle you are welcome to drive my Z4MR. My diagnosis was 100% the same as yours and I'm now very happy with how my car drives.
plenty said:
Even taking into consideration the positioning of the springs, the OEM wheel rate is too stiff at the rear and too soft at the front.
On a front-engined car you want harder suspension at the front as there is more weight at the front, especially with the heavy iron S54 block on the Z4M. Furthermore, the seating position on the E8x is so close to the rear axle that you want as much compliance at the rear as possible.
The OEM suspension is a strange combination of the front end being too soft, contributing to poor turn-in, a general feeling of vagueness, lift under hard acceleration and dive under braking, but also a jittery ride and a back end that hops and skips over bumps rather than absorbing them, due to the lack of compliance at the rear. The end result is a car that does not reward being pushed hard and has the sensation of the front and rear being disconnected, as if you are driving halves of two different cars that have been spliced together.
Most aftermarket suspension including BC and KW fixes this with wheel rates that are higher at the front than the rear, making for a more planted, confidence-inspiring and cohesive drive.
The Caterham is another example of a car which is front-engined with the seating position close to the rear axle. Most Caterhams run wheel rates at a delta of roughly 2F:1R. The only cars which have stiffer wheel rates at the rear are mid- and rear-engined.
I love tech discussion, what data would you have to indicate the rates are off, either soft or stiff, you do realize that despite engine and drive positions, the Z4 is close to 50/50 weight distribution. I think is 52/48 and about 49 cross-car. so it is pretty balanced.
The rears can be a bit softer, yes, the OE rear springs are progressive and the rate ramps up quickly at the rear to be close to 700#/in. however, that can be remedied with different rate springs (preferably linear), but again, not by much. equal rates front and rear are incorrect, again, if you match them you now have a soft rear and the wheel will not settle after a bump, and the car will jack down, and ride the stops as a result which will make the ride even shittier. Have a look at videos from Fatcatmotorsports in youtube, he does a very good job in getting this message accross.
Interestingly, I loved the way my Z4 3.0 handled. Hopefully someone more informed than me can explain why I find the Z4m so woeful in comparison. My only gripe with the 3.0 was that it understeered a bit (fixed with a stiff rear ARB). I always chucked that car around a track with a massive smile on my face, in standard form I can't say the same of my Z4m. I can't wait to refresh the suspension and see what this beast can do. Here is a cheeky vid of my old 3.0 in action, the little car that could.
https://www.youtube.com/watch?v=TW7KSQ1ta8U&t=28s
I’m more interested in the outcomes than the technical details, and I’m no engineer but I do enjoy modifying my cars to make them handle better.
I’ve noticed a relative lack of discussion and evidence on topics such as spring rates and weight distribution for the Z4 compared with other makes I’ve owned, which I attribute to an ownership base which tends to be more GT than sports, and because these cars are rarely used on track. I’m not a track person either, but cars that are popular on track tend to have a much deeper knowledge base.
I’ve seen the 50/50 weight claim mentioned frequently. There’s not a lot of available evidence of this, but I have no reason to doubt it. But I note that weight distribution presumably cannot be the same for an S54-engined car whose engine is significantly heavier than say the N52. Meanwhile the impression from my driver’s seat is very much one of front-heaviness, exacerbated by a driving position far from the front axle which magnifies the pendulum feel.
Many road tests and indeed the OP of this thread have described the same symptoms I felt when I first acquired the car, of the disconnect between front and rear. A vague front which does not inspire confidence during hard turn-in, combined with a lack of compliance (and poor damping) at the rear which causes the car and driver to bounce all over the place on anything less than well-surfaced roads.
It therefore made sense to me to look into stiffening the front and softening the rear. And it’s perhaps not a coincidence that this is also the approach recommended by the likes of BC and KW with their default spring rates. I also suspect that BC and KW damping is better-matched to their springs compared with OEM.
I can understand this concept, but my experience suggests that you would need massively softer rear wheel rates and massively harder front rates before it manifests.
Using your spring to wheel rate ratios of 0.9F and 0.45R as a guide, the stock BC setup offers a delta of 1.2F:1R and this feels substantially better than stock. In fact on stock 6 kg BC front springs turn-in is still not as precise as I would like, and I aim to experiment with 8 kg springs at some point which would give a 1.6 delta.
My hunch is you’ll need a delta of of >2:1 before the problem you describe actually occurs, and that a delta of between 1.5:1 and 2:1 is ideal for our cars.
From a video on YT where they weighed the car
For your turn-in dilemma, put the CSL front sway bar. I have it, + the CSL alignment settings and the car is very eager to turn it.
https://z4-forum.com/forum/viewtopic.php?t=102312&start=150
This thread may assist in the question of weight, and weight distribution... :)
CSL geo already applied. Thicker front bar makes sense to me in theory, as I only require added stiffness in cornering and not in a straight line. Will look into it - thanks.
Are you suggesting the CSL bar is stiifer? I ask, as whilst it is a little wider it is also hollow, given the mass decrease I'm not convinced it necessarily is. I also have one fitted, I can't find any info about the relative specs online.
Turn in for me was most obviously affected by toe adjustments at the rear. This is with quite aggressive front camber/neutral toe.
I thought that a thicker ARB on the front would worsen understeer?
My old Z4 had adjustable ARB's and I experimented with many different settings. If I stiffened up the rear turn in was better, if I stiffened the front it made things worse.
Correct, all things being equal stiffening the arb will effectively remove grip from that axle, but in the case of the front it will reduce roll so will give the feeling of it being sharper to turn in.
Indeed correct, and any understeer issues can be dialled out with camber etc.
That's the fun thing about suspension tuning - there are many ways to achieve a similar effect, everything is interconnected meaning a change in one area always affects other areas, and the goal is to get all the variables working holistically to your liking.
