Battery removal- Z4M coupe
Rags
Hi Folks
Struggling with the most simple task - removing the battery.
I have accessed the battery by removing all the trim.
The standard bmw locking pin has been removed and i have removed the positive and negative terninals.
However the battery wont slide out - is there another lock pin located somewhere else? :driving:
IIRC it can get wedged on the plastic base. You had to sort of lift it up and slide it forward at the same time.
It should just pull out with a bit of a wiggle. Even I managed to do it!
