colb said:If the radio is dead what about the Aircon and heated rear screen? If these are also dead your car is in transport mode low battery condition will set this to close the systems down to conserve what power is left for starting. If it is in transport mode you need a scanner capable of resetting it to Normal, doing so restores the systems to working. Be aware not all scanners can reset this.BMW scanner 1.4 on a laptop can reset it but not delete it to avoid this happening again. High end tablet scanners like Launch and Autel can delete it permanently, they remove transport mode from all theodules that have it in one operation, something that the selling dealer/stealer should have done when doing the PDI on the car, probably foresaw £££'s as sooner or later owners would end up with transport mode and have no clue as to what's going on.Radio in Z4 doesn't need a code unless it's been fitted with an aftermarket radio.
Yes Aircon and heated rear screen are also not functioning. I suspect the car might have gone into transport mode. Thinking to get a BMW scanner 1.4 and check this myself.
