maxman said:
I have my ctek connected to the battery in the boot,have done it this way for nearly 12 months with no problems.The connectors under the bonnet are there for jump starting in the main.I am not saying it's wrong to charge that way ,just it's not a must do .
I love it when people read the wh
ole thread before replying..
Long dissertation is here..
https://www.newtis.info/tisv2/a/en/e89- ... ly/YDj5gs8
Short version..
Notes for Service department
General notes
Notice! Charging and trickle charging of the battery
The battery may only be recharged with a battery charger that has been approved by BMW and that has a constant charging voltage of 14.8V.
If possible, the battery temperature should be between 15 °C and 25 °C during charging. Under these preconditions, the battery is adequately charged when the charge current drops below 2.5 amps.
If the battery is recharged at low temperatures, the charging procedure should not be ended until the charge current drops below 1.5 A.
On vehicles with IBS, recharging the battery directly at the battery terminals could lead to a misinterpretation of the battery condition and even unwanted Check Control messages or fault entries.
If the battery is recharged while it is installed, it must be recharged using the jump start terminal points, whenever jump start terminal points are provided in the engine compartment. Only then can you be sure that charging is correctly recognised by the vehicle electronics on vehicles with an intelligent battery sensor (IBS).
SO NO DO NOT CHARGE THE BATTERY ACROSS ITS CONNECTORS!!!!!!!!!!!!!!!
