I know, it's discussed all the time, particularly on a million other car forums, but there's something I can't find an answer to - every listing for the B12 Kit that I have come across that is described as for the 35is also specifies that it is not for cars with electronic suspension systems. Does that mean I can't fit it to a car with adaptive suspension, or just that the adaptive suspension will no longer work?
If anyone has any general opinions/experience on the B12 compared to other options or the stock adaptive suspension I would also be very interested to hear. I'll definitely be going aftermarket when mine needs replacing, and perhaps even sooner (B12 for under £600 seems like a "might as well just do it" kind of situation if it's going to be a significant improvement). I'd like to reduce roll in corners, primarily, lowering a little is fine but definitely nothing more than 20mm (<10mm would be preferable) and I'm not worried if the ride suffers somewhat as a result (as long as not too bad).
I imagine Ohlins and KW would be better, but for the way I drive and the roads in this part of the country I just can't convince myself that 10+% of the cars value spent on damping is worthwhile for me. I am trying though
