You want it back then buddy? I may save up for the better mini one, any links?
sk93 said:it will only show up on the radio when there is a bridged connection between the aux output channels on the back.
Quadlock is the name for the connect on the end of the wires.
Whilst it's not 100% needed, as you can buy a couple of pins from maplin for about £2..
however, I'm not sure that the cable shown on that eBay item actually has the right connector on it.
The ones in the back of our stereo can be seen in many images earlier in this thread.. it's quite small and compact... this looks like an older version BMW used to have.....
a11y said:Aux cable for £10 - link in this thread: http://www.z4-forum.com/forum/viewtopic.php?f=31&t=33609#p455854
Simply plug n play - I've been using one for a couple of years now.
a11y said:Buy THIS aux lead for a tenner, and route it into the glovebox - that's what I've done although I rarely use it as I've also got a (functional!) 6-disc changer but also an OEM MP3-disc playing headunit.
Fitting the lead is REALLY easy once you've got the centre air vents out - DIY guide is on the site if you have a search I'd think.
a11y said:I don't recall that info previously when I bought mine - fairly certain I don't have those inline bits, and that was starting with my 54-plate pre-facelift that originally had a non MP3-disc playing headunit.
I just used that basic cable in the link - can't recall there being any resistors or the like when I fitted mine a couple of years ago. And that was to a 54-plate, July-2004 built 3.0i fitted with a later MP3-playing basic business headunit from a facelift Z4/X3. Works perfectly and AUX displays and was enabled.sk93 said:You definitely need resistance across the two outputs. The headunit doesn't display "AUX" now, and simply extending the pins with wires isn't going to signal the headunit to enable it; it checks for current across the two and if it's there, it enables the AUX output.
Trust me; I built my own cable the hard way![]()
